Banging from Propshafts
Posted: Sat Sep 26, 2015 3:14 pm
by dan-wilks
Really struggling to diagnose this by myself, when I attempt to pull forward or backwards I get a small soft bang followed shortly by bigger knocks from somewhere, it only does this when I try to move, I found that the front Propshaft had been hitting the chassis due to two broken transfer mounts which I thought was the problem and have now replaced but the banging is still there.
Any ideas would be much appreciated
Re: Banging from Propshafts
Posted: Sat Sep 26, 2015 4:05 pm
by gamble63
It could be your ujs on the prop, what you wanna do is get underneath it and grab the prob sharft and rotate it with your hand back and forth, if there is any form of play in the uj then it is pretty much fooked and you need a new one:
here us a video of one that is really gone but you are looking for similar play:
https://www.youtube.com/watch?v=4Q9MR_KocHk
Posted: Sat Sep 26, 2015 6:32 pm
by dan-wilks
Brilliant thank you
Posted: Sat Oct 10, 2015 5:12 pm
by dan-wilks
An update....so replaced one seized uj but after fitting it back together found out that my transmission brake is also knocking!
Posted: Mon Oct 12, 2015 4:26 pm
by gamble63
have you taken off the transmission brake hub to have a look inside?
Posted: Fri Oct 23, 2015 12:43 pm
by dan-wilks
no i havent, wouldnt really know where to start apart from get the propshaft off then the locking nut
Posted: Sat Oct 24, 2015 12:29 am
Thats about it. Prop off, flange nut off and knock the *#%¥ outta the drum till it comes off.
You don't need a fancy tool to get the nut off either. A good breaker bar and a mate, stick it in 4wd and get a mate to put their foot on the brake, locks the transmission up.
Posted: Sat Oct 24, 2015 12:49 am
by ROBBIE
If the beating the crap out of it method doesn't work, you could always wind the shoes in
Posted: Wed Dec 09, 2015 7:06 pm
by dan-wilks
finally pulled my finger out and had a look! turns out the shoes for the handbrake had stuck and left a lump of friction material along the casing which was causing it to knock against that!
Posted: Thu Dec 10, 2015 2:24 am
by Anton
:shock:
