SJ fuel tank.
Posted: Mon Nov 09, 2015 10:53 pm
by badoffroader
Does anyone out there know how many wires go to the in tank fuel pump in an 1995 injection SJ and what loom/part of the wiring they're routed from.Ta.
Re: SJ fuel tank.
Posted: Tue Nov 10, 2015 8:10 am
by dan_2k_uk
Someone must know this?
Re: SJ fuel tank.
Posted: Tue Nov 10, 2015 8:13 am
Honestly not a clue... my parts man has the pumps and sensors new but they are for a 1998+ injected maruti gypsy. If you get stuck I'll check it out when im there later this week
Re: SJ fuel tank.
Posted: Tue Nov 10, 2015 8:19 am
by badoffroader
Thanks,the reason i'm asking is that i've taken the tank out,cleaned it up and repainted etc,put it back in and now the in tank pump is'nt working.Rather than take the tank off again i wanted to check how many wires go to the actual pump - i can only see one
Re: SJ fuel tank.
Posted: Tue Nov 10, 2015 8:21 am
Ahhh yes just for the pump I believe there should just be a positive power supply and the pump earths through the tank
Re: SJ fuel tank.
Posted: Tue Nov 10, 2015 8:42 am
by courior
and if the paint is thick that would explain why the pump isnt working as its not grounding.
Re: SJ fuel tank.
Posted: Tue Nov 10, 2015 3:31 pm
by badoffroader
Thanks for that - i did wonder if there was supposed to be an earth via the tank body but i thought that sounded a bit dodgy so was looking for an earth wire going directly to the in tank pump.I'll give that a go tonight,cheers.
