Will diesel gearbox fit to benzin engine
I have 1999 benzin 2l 4cyl Vitara manual which has gearbox bearing problem, i could get cheap gearbox from diesel Vitara but will it fit?
Re: Will diesel gearbox fit to benzin engine
Hi, diesel gearbox won't fit directly on a petrol engine.
You may be able to remove the bell housing from the petrol gearbox and attach it to the diesel box but I don't know if it would work
twiss wrote:Hi, diesel gearbox won't fit directly on a petrol engine.
Thanks for the info.
Bellhouse change is not so bad job, but is input shaft same?
Has anybody done this? I could not find anything whit google...
I would go ask a parts shop for the clutch release bearing (maybe the clutch plate as well) for the petrol and diesel to see if they are the same...
Probably being dumb, but will not a diesel box have totally different ratios?
Yeah they should be much higher
Usually Suzuki just re gear the final drive....aka the diffs.
Rock auto cluch kit:
Benzin: tooth number 20
Diesel : tooth number 21
So input shaft is not the same. Could i use diesel cluch kit?
Does diesel have wire driven cluch or hydraulic?
