Rear hub wobble
- robbie1985
Rear hub wobble
So I noticed that there was oil leaking out the rear drum on the passenger side and figured that it was just a wheel cylinder leaking so went to replace it and it turns out that the leak is coming from the hub. There is a shit ton of play both up and down and in and out. So I'm thinking that it's bearing nod was wondering How tricky is it to replace?
