So, i need to fettle and fiddle a sj413 back to the little fella's beastly best
Wheres the best place for service parts?
First off a want an ignition overhaul kit, plugs points, HT leads ect
Cheers.....adam
sj service parts
Re: sj service parts
Your local motor factors should be able to get everything you'll need for a full service.
Ah right cheers, thought there might be a specialist tucked away somewhare that you lads use
Theres a couple in Malta but that's probably not much use
