SJ410 and SJ413 rear lights and connectors
Pugsley
Post by Pugsley » Thu Oct 15, 2009 8:08 pm
I've been on the lookout for sometime for a replacement LH rear light assembly in good condition - nothing found so I'm thinking of buying a new set (pair) as currently advertised on Ebay at £26.99 plus postage (From Thailand).
Has anyone any experience of these - I would appreciate your comments and most important - they are advertised as for a SJ413, will these be a direct fit for my SJ410 (1988)?
They look identical but my concern is the plug connector are they the same on both vehicle types?
Would appreciate any comments you have to make as I need to get going on this.
Thanks
Re: SJ410 and SJ413 rear lights and connectors
Post by ScottieJ » Thu Oct 15, 2009 10:40 pm
I cant imagine that the connections will be different :?: have they ever changed on the sj :?:
it isnt hard to swap them over if they are different! soldering iron and a bit of heatshrink :mrgreen:
Pugsley
Post by Pugsley » Sat Oct 17, 2009 9:14 pm
Now sorted thanks - decided to get a new set via Ebay.
Henry
Post by Henry » Sat Oct 17, 2009 9:16 pm
Hi, good choice.
If your ianc2051 off difflock then you already know what i said (henry)
Henry
Pugsley
Post by Pugsley » Sun Oct 18, 2009 7:53 pm
Hi Henry
Yes I'm one and the same - will let you know what I think of them on arrival (9-15 days).
Pugsley
Post by Pugsley » Sat Oct 24, 2009 5:49 pm
Just to give you an update as promised - the rear light set from Thailand arrived this morning and are now fitted including connecting up the wiring for my tow bar. I was amazed at how quick the delivery was - about 9/10 elapsed days - they work fine and although they are advertised on Ebay for a SJ413, they do fit a SJ410 and the connectors are identical. The supplier cannot advertise them as being suitable for a SJ410 as this model was not marketed for Thailand.
