SJ vibration
Posted: Sat May 28, 2016 7:48 am
Any ideas please - I am getting a rough vibration under acceleration and decelleration (so when engine is under most load I suppose), mostly in mid rev range. I can feel it through the steering and hear it too.
Engine mounts look fine / solid. I'm guessing it is caused by dodgy mounting somewhere along the engine / gearbox/transfer case area? If it was prop shafts it would not be rev dependent (my guess) - it runs smooth and good at steady speeds.
Had a new clutch with bearing a few miles ago, so it won't be that.
Any ideas where to start looking and how to check?
Thanks all, as usual
