Swapping over front bases
Posted: Tue Jun 28, 2016 3:15 pm
by Eltoon
Hi, any reason I couldn't swap just the front seat bases (i.e. the bits you sit on) over? Not the frames or sliders, just the sitty on bit? My drivers side one is worn out but the passenger side is good so if I could swap them over that would be handy! Means I could still drive the car and get the other one repaired.
Re: Swapping over front bases
Posted: Tue Jun 28, 2016 3:34 pm
If it's an SJ then they have completely different mounts on each side normally so you won't be able to.
Posted: Tue Jun 28, 2016 4:20 pm
by SherwoodNash
Eltoon wrote:Hi, any reason I couldn't swap just the front seat bases (i.e. the bits you sit on) over? Not the frames or sliders, just the sitty on bit? My drivers side one is worn out but the passenger side is good so if I could swap them over that would be handy! Means I could still drive the car and get the other one repaired.
I had the same problem, in the end I replaced both front seats from a slightly later model.
A couple of years ago, SJ seats were coming up regularly on eBay, now, hardly ever.
Posted: Tue Jun 28, 2016 4:39 pm
by Eltoon
Curses foiled again! Ok cheers! (Sorry, yes, it is a Spanish SJ)
Posted: Tue Jun 28, 2016 4:59 pm
by SherwoodNash
If you replace both, save the good one! makes a great 'puter chair, just fix to a cheapo base :D
http://forum.suzukiclubuk.co.uk/vi ... it=+wanted
Posted: Tue Jun 28, 2016 6:57 pm
Get some more comfy seats and put them in there ;)
