1.6 Vitara engine in Sj what back box have u got ?
- dazerede
Got a 1.6 Vitara engine in mine atm and currently doing the exhaust system running 1.3 manifold and and n ed ideas of what back box have you got that fits Also got a tow bar fitted so it's a tight fit around the fuel tank
4” calmini lift kit
4” calmini lift kit
- dazerede
Re: 1.6 Vitara engine in Sj what back box have u got ?
Or will try and fit this big bore back box it is quite long
- image.jpeg (140.2 KiB) Viewed 8426 times
4” calmini lift kit
4” calmini lift kit
I made a custom system from the outlet of the mid box back as the standard system is quite restrictive after that but not too bad before there.
Cherry bombs fit well in the gap next to the tank. Take a look in my build thread.
- dazerede
Ye I did have a cherry bomb on it when I had the 1.0 engine but will try this back box only thing is that when the rear axle moves up it might touch the back box will see what it's like when I go off-roading lol
4” calmini lift kit
4” calmini lift kit
I would have thought that would fit. It's the clearance to the shock you need to worry about if they are still mounted in the standard position.
Back box? Whats one of them?
jordi - lol
daz -
when i first put a 1.6 in i was using the stock 1300 exhaust pipe front to back.
Then I broke the backbox off and put a cherry bomb and did notice an actual improvement in performance
I think the 1300 one is quite restrictive to the 1600. Personally if you have the time I would probably replace the front box as well.
Maybe just straight through
daz -
- dazerede
Ye it is currently 1.3 manifold and the rest is straight through pipe around 45mm wide was going to use the 1.6 manifold but the bolts that hold the exsaust on are sized will get a pic tomorrow
4” calmini lift kit
4” calmini lift kit
45mm should be plenty for the 1.6, unless you plan on boosting it
- dazerede
Haha i think I've done enough on it lol won't get insurance else
4” calmini lift kit
4” calmini lift kit
