Do I need this on the tow bar
dazerede
Post by dazerede » Sat Jul 23, 2016 4:22 pm
Can't fit this on with my back box is it needed it bolts to the chassis rail and to the bottom of the tow bar thanks
4” calmini lift kit :)
dazerede
Re: Do I need this on the tow bar
And no I'm not removing the tow bar if anyone says that lol
Post by Jordi » Sat Jul 23, 2016 4:55 pm
I would say so. Its a strengthening brace.
SherwoodNash
Post by SherwoodNash » Sat Jul 23, 2016 6:02 pm
Jordi wrote:I would say so. Its a strengthening brace.
I have the same tow bar as you, it was an original authorised Suzuki fitted part.
When I fitted my new fuel tank recently, I took off the tow bar and that brace for access. I thought about not installing that bit too, just for cleaner lines but thought better of it, so it went back.
Also, you should have a 'sleeve' for the long bolt that sits inside the chassis member hole fixing point. Mind you don't tilt it when putting bolt in as easy to fall inside the box section and rattle around forever!
dazerede
Post by dazerede » Sat Jul 23, 2016 10:25 pm
Ah ok guys will have to modify the bracket then cheers
Post by andyrew » Sun Jul 24, 2016 9:12 am
My towbar is a similar design and doesnt have the brace. Some do
some dont. Id be more inclined to change the back box as that
looks like exhaust rattle mania.
Post by ROBBIE » Sun Jul 24, 2016 1:33 pm
I never had that bar on mine, never used it for towing only recovery. And yeah that looks well rattly
SherwoodNash
Post by SherwoodNash » Sun Jul 24, 2016 3:37 pm
ROBBIE wrote:I never used it for towing only recovery.
I do both! I added a S/S 4Tonne D shackle :D
http://www.ebay.co.uk/itm/310607674262
Post by ScottieJ » Mon Jul 25, 2016 10:19 am
Are those shackles actually tested and rated? Being only 12mm diameter I would not trust it for anything but a very light recovery. Considering rated 3.25T shackles usually have a 18+mm pin I highly doubt those can handle 4T. Personally I will only use tested and rated shackles with the correct markings for recovery, I have seen what can happen when recovery gear and points fail and it can be fatal.
Do they carry any of these markings?
https://www.prolyte.com/en/prolyte-camp ... g-shackles
http://www.electricwinchshop.co.uk/3-25 ... ackle.html
SherwoodNash
Post by SherwoodNash » Mon Jul 25, 2016 10:53 am
It pulled out a Isuzu double cab 1 tonne pick up from a pub car park ditch OK.
I've learned from all those (especially Oz) recovery vids on YT, and followed all the rules.
