Buzzing noise from large heat sync under passenger side dash
- SlimGrim
- Winching along now
Under the dash above the passenger side footwell is a large round aluminium heat sync, which has recently taken to clicking really fast when the engine is running until I turn the lights on at wich point it stops, the noise returns when I turn them off again, any ideas on what this is and why it could be doing this?
___________________
- SlimGrim
Re: Buzzing noise from large heat sync under passenger side
This
- image.jpeg (213.19 KiB) Viewed 7919 times
___________________
Think its the dim dip relay. Should be OK to just unplug it
It's your AirBag ECU, or Flux Capacitor
2002 Jimny O2 Ragtop
Wessex 4X4 Reponse - WE411
wessex4x4response.org.uk
- SlimGrim
I have an airbag!?
___________________
haha, nope! I do. If it works or not is another question!
- donkeychomp
I have the same issue with my LJ and the noise stops when I brake. Why it does this is a complete mystery.
Dim dip unit. Unplug and chuck it.
- SlimGrim
is it useless or should i replace?
___________________
No need to replace
