suzuki grand vitara ddis rear crank oil seal
meathumper
Post by meathumper » Sat Oct 15, 2016 7:10 pm
Hi all, has anyone done the rear crank oil seal on the 1.9 ddis. Ive read that there it some gunk to be placed between the crank end cap and the block to make a better more permanent seal. Unfortunately thats all the info i got, can anyone shed some light on this or explain the job better please. thankyou.
Re: suzuki grand vitara ddis rear crank oil seal
Post by Darrell » Sat Oct 15, 2016 9:13 pm
The appears to be issues as regarding sealing the crankshaft bearing cap 1. Suzuki in there wisdom decided to use 2 rubber strips that don't seem to do the job properly. Mitsubishi use sealant and hardener, but I can't find references for the hardener or syringe used. I've put together what Ive found .........
meathumper
Post by meathumper » Sat Oct 15, 2016 9:50 pm
Arr, that explains it. Would rtv do the job do you think? Thanks
Post by Darrell » Sat Oct 15, 2016 10:09 pm
I'm really not sure. I would try posting it on here http://www.suzuki-forums.com/index.php? ... ive_topics as it has a wider audience. No disrespect for Suzukiclubuk but here we mostly deal with older SJ's and Vits :thumbup: .
meathumper
Post by meathumper » Wed Oct 19, 2016 8:10 am
ok thanks for your help.
zook123
Post by zook123 » Wed Oct 19, 2016 1:17 pm
RTV sealant would do the job, although mine is leaking on the Jimny, decided to keep an eye on it, and it's stopped. Result!
2002 Jimny O2 Ragtop
Wessex 4X4 Reponse - WE411
wessex4x4response.org.uk
Post by ScottieJ » Wed Oct 19, 2016 1:20 pm
Darrell wrote:I'm really not sure. I would try posting it on here http://www.suzuki-forums.com/index.php? ... ive_topics as it has a wider audience. No disrespect for Suzukiclubuk but here we mostly deal with older SJ's and Vits :thumbup: .
and LJs and Jimnys :brows: :lol:
