4 wheel drive noise
lukey4x4
4 wheel drive noise
Post by lukey4x4 » Sat Oct 15, 2016 9:23 pm
Het guys well today i finally done / etempted offroading first time since its bin finished and it lasted about 1 minute lol so i drove down to the place i was going as normal everything fine first bit I etempted was a big bank so i got put locked the hubs and put it in 4 low and awAy i went up the bank and hurd this clicking/clanking noise so when i got to the top and got out to investigate gpt my mate to drive it around and seemed like every time i turned whilst moving it would make this noise couldnt properly locate where it was coming from on the front axel diff ,hubs, halfshafts so after my 1 minute of offroading i put it back in 2wd and hubs back to free and noise goes drives as normal , any ideas anyone before i rip it to bits , thanks
Re: 4 wheel drive noise
Post by Jordi » Sat Oct 15, 2016 10:37 pm
Possible clicky CV joint?
Try driving it in 2wd but with the hubs locked and see if it makes a noise.
lukey4x4
Post by lukey4x4 » Sat Oct 15, 2016 10:55 pm
Cheers jordi will see it it does that tomoz , Is it something that can be fixed or is it just a case of replacing it jordi everytime i turned the wheel n moved it would clank couldnt tell where the noisr was coming from sounded like both sides , thanks
Post by Jordi » Sun Oct 16, 2016 8:30 am
New CVs would be required.
lukey4x4
Post by lukey4x4 » Sun Oct 16, 2016 10:16 am
Cheers jordi will i know if there nackered when i see them , how would i check to make sure , thanks mate
Post by Jordi » Sun Oct 16, 2016 1:09 pm
Lock the front hubs and drive it round going from full lock left to right and you should be able to hear it clicking round and possibly feel the feedback through the steering wheel.
Further investigations is to jack it up and take both front wheels off and again move it lock to lock whilst trying to turn it manually. It should jam up.
Also possible the tyres are catching on the spring / bulkhead but being SPOA should be unlikely.
lukey4x4
Post by lukey4x4 » Sun Oct 16, 2016 3:34 pm
Cheers jordi yea went over this morn put it in 2WD and locked the hubs and nonoize but it in 4WD and yea it makes the clicking and can sort of feel it jamming abit noise seems like its coming from both wheels , all bearing n everything is brand new , anyways stripped 1 side all down n pulled cv out cleaned it up abit for better look how do i tell if its nackered all bearing r intact n looks ok any ideas ,thanks
stevepsj413
Post by stevepsj413 » Sun Oct 16, 2016 5:21 pm
If it is the cv's then you should still be hearing the noise with the hubs locked with it in 2wd. With the hubs locked its turning the half shafts and cv's as the wheel moves. But if you have the shaft out you should be able to feel it with your hands, as jordi said it would feel notchy/bind up. Have you checked the uj's on the front prop? It does sound like the cv's to me tho so I think it would be worth checking both sides as these noises can travel through the axle and make it hard to tell which side there coming from.
lukey4x4
Post by lukey4x4 » Sun Oct 16, 2016 6:24 pm
Cheers mate , yea definitely didnt do it in 2WD wif hubs locked like but it stright in 4WD and done it stright away quite loud only on lock as i was turning i could feel it through the weel like bumpy n as it made the noisei felt like i needed to stop as was gunna smash something , yea i have it out but not to sure on what its ment to be like lol like a said all bearings r intact , not sure if they r standard but heres a few pics , there is a tiny abit of play in the front uj but not a great deal to make that noise a would have thought , thanks
zook123
Post by zook123 » Mon Oct 17, 2016 8:35 am
Wouldn't be diff wind up would it?
2002 Jimny O2 Ragtop
Wessex 4X4 Reponse - WE411
wessex4x4response.org.uk
