09 M13A auto - Intermittent no start condition P1621
Posted: Fri Nov 18, 2016 5:41 am
by FJ43
Hey guys!
I have a 09 with a M13A and auto transmission.
There is a intermittent fault with the vehicle not starting occasionally. When this happens, a fault code logged is P1621
I have tried another ecu/iimmobiliser/key set from a running vehicle with exact same numbers but the problem still persists.
Has anyone faced a similar issue or had the same code logged.
Would be very grateful if someone could shed some light as to where i should look.
Thanks.
Re: 09 M13A auto - Intermittent no start condition P1621
Posted: Mon Nov 21, 2016 7:58 am
by zook123
Swapping over the parts mentioned won't work anyway as they would need to be paired. Have you tried the spare key?
