gears on auto
gears on auto
hi my suzuki seems as if it has clutch slping but is auto can any one help
Re: gears on auto
hi yes its ok but still slip when you rev to goScottieJ wrote:Have you checked the transmission fluid level?
Re: gears on auto
Did you check the fluid level with the engine running and after it has warmed up. fluid level and condition plays a big roll in how an automatic transmission works, if it runs low then it can make it feel like a clutch is slipping.
http://www.aa1car.com/library/transmission_slipping.htm
If it's not that then it will have to go to a specialist to be looked at.
Also which model suzuki are we talking about? there has been a number of different automatic transmissions used.
