Throttle position sensor, Where to buy cheaper??
Posted: Tue Jan 24, 2017 1:02 pm
by villagehoppa
Hi All,
I need to get a throttle position sensor for my 95 1.3 Sj, most other makes are around the £30 mark but could only find a couple for the SJ for over £100!!!?? Any one know why and where else I get a cheaper one!!!? many thanks...
Re: Throttle position sensor, Where to buy cheaper??
Posted: Tue Jan 24, 2017 1:15 pm
by ROBBIE
Have you tried a motor factors? My local, gone now
, used to try loads of suppliers to get me a good deal
Posted: Tue Jan 24, 2017 1:27 pm
by zook123
Send me in a PM your reg plate and I'll do some digging
Posted: Tue Jan 24, 2017 1:57 pm
by zook123
Cheers, my system didn't find anything, but I did find this..
http://www.ebay.co.uk/itm/SUZUKI-SWIFT- ... SwB09YSf9c
If they confirm that it has the TPS still on it, which it looks like it does, then that would fit!
Posted: Tue Jan 24, 2017 7:23 pm
by villagehoppa
Fantastic, thanks for that, got a good motor factors round here actually so I might see if they can get me a new one cheaper, failing that, the Swift It will be...
Thanks all...
Posted: Wed Jan 25, 2017 6:51 am
The only for the injection Maruti Gypsy might be the same. I can probably get those. Has it got a part/code number on it?
Posted: Wed Jan 25, 2017 8:34 pm
by villagehoppa
Thanks for that, I'll get it off this weekend and have a look for the part number..
Posted: Tue Feb 07, 2017 9:55 pm
by Rhinoman
Have you confirmed that it is faulty?
Posted: Thu Feb 09, 2017 10:08 am
by villagehoppa
I've put the fuse in to see if there are any codes but they are all fine, there is no code, just the all clear code!?! Think I'll have to check all the hoses and see if there's a leak to why it runs so fast on start up from cold!! The plot thickens....
