Starter motor on 1.6 8v 1993
Guesty1191
Post by Guesty1191 » Mon Feb 06, 2017 7:18 pm
Need some help my starter motor is playing up which other ones fit?? Cheers
Re: Starter motor on 1.6 8v 1993
Post by ScottieJ » Tue Feb 07, 2017 12:17 am
What is it doing....or not doing.
Mignt just need a strip and clean
Guesty1191
Post by Guesty1191 » Tue Feb 07, 2017 6:41 am
Its just clicking had it off once. I seen somewhere that other starter motor fits it. Do u know any?
Post by ScottieJ » Tue Feb 07, 2017 9:38 am
How thoroughly did you strip and clean the starter?
Also check the wiring, it could be that it's not getting enough current to the trigger wire. test this by using a bit of wire from the trigger connection to the positive
on the battery with the ignition on, if it starts easily like that then it's a wiring issue.
I presume it's in a vitara? If so just get one listed for an sj or vitara etc. they aren't hard to find.
