prop lengths?
palo123
prop lengths?
Post by palo123 » Thu May 18, 2017 1:58 am
Hi, was wondering what the prop lengths are for a fat propped sj410 front and back props?
Also will 413 ones fit a 410 or are they longer?
And are there variations of different spline counts on the intermediate prop which goes to the gearbox for a 410?
Just trying to buy some props and the breaker doesn't know what ones he has so I thought I'd tell him the measurements. :D
Any info is a appreciated
Pete
Re: prop lengths?
Post by ScottieJ » Thu May 18, 2017 12:33 pm
Spline counts are all the same on intermediate props. There's 2 different lengths though as the earlier 410 4 speed boxes are shorter.
413 and samurai props are around 25mm shorter than 410 props.
I've got an unfinished list of prop lengths somewhere, I'll find it
Re: prop lengths?
Post by ScottieJ » Thu May 18, 2017 12:36 pm
palo123
Re: prop lengths?
Post by palo123 » Thu May 18, 2017 4:23 pm
Cheers Scottie,
So a 410 front prop should be 717mm compressed length. But what about the rear prop as that's not on your table?
ScottieJ wrote:Spline counts are all the same on intermediate props.
I have a set of skinny props and the intermediate prop won't fit the output on a 5 speed 410 Santana gearbox as the output shaft is too big in diameter.
Re: prop lengths?
Post by ScottieJ » Thu May 18, 2017 4:46 pm
Sorry, spline count is the same on all fat intermediate props that should have said.
Without measuring some props in the workshop I couldn't say.
If I get a chance I'll measure some this weekend if that's ok?
The fat 410 props should be the same lengths as the skinny 410 props I think.
palo123
Re: prop lengths?
Post by palo123 » Thu May 18, 2017 6:29 pm
Thanks Scottie, i've got a full set of skinny props for my other sj410 so i'll measure them and see how they compare.
Pete
palo123
Re: prop lengths?
Post by palo123 » Thu May 18, 2017 7:56 pm
One last question, can i change the flanges on a skinny prop t box to suit the larger prop bolt spacing by simply bolting on the bigger flange, or are the splines different?
Thanks,
Pete
Re: prop lengths?
Post by twiss » Thu May 18, 2017 8:25 pm
Flange splines are different for the really skinny props (look like maccy d's straws ;) )
palo123
Re: prop lengths?
Post by palo123 » Fri May 19, 2017 11:35 am
Thanks Twiss, looks like ill have to get another transfer case with the bigger flanges.
Re: prop lengths?
Post by ScottieJ » Fri May 19, 2017 12:14 pm
what year is it? some of the crossover 410s had skinny props but with the later style tbox i think so there is a chance that you can swap the tbox flanges.
