Checking speedo cable.
Robert.m
Post by Robert.m » Wed Jun 21, 2017 7:11 pm
My Samurai speedo doesn't work, if I disconnect it from the transfer box to see where it's broken will the oil run out? Thanks
stevepsj413
Re: Checking speedo cable.
Post by stevepsj413 » Wed Jun 21, 2017 7:20 pm
No mate it won't run out of where the speedo cable goes.
Robert.m
Post by Robert.m » Wed Jun 21, 2017 7:25 pm
Thanks, just thought I better check with it being connected below the oil level. Cheers
Robert.m
Post by Robert.m » Wed Jun 21, 2017 7:45 pm
Unfortunately it's not the cable, the flat drive for the cable is turning freely, how easy is it to change the speedo drive pinionor worst case scenario it's the driver, gulp!
Post by twiss » Thu Jun 22, 2017 12:36 pm
Did you actually check the other end is spinning? if its broken in the middle, the tbox end can spin fine but the other end will stay put
Robert.m
Post by Robert.m » Thu Jun 22, 2017 8:14 pm
Yeah, dragged the Mrs in the garage to check,
Took the drive pinion out and it looks fine so it's the worst case scenario - the worm is worn out !! I can just see inside and there is definitely a large groove worn in the gear .
Can the worm be changed without taking the TB out and stripping it down ?
