Anyone know the lengths of the 410 or 413 Right & Left Inner Half Shafts compared to the Samurai ?
The specs thread lists the 413/410 axles being 3" narrower hub face to hub face.
So, is each half shaft 1.5" shorter than the Samurai ? The outer stub axles are the same lengths so the inner half shafts should be that much shorter.
But if the stub axle is 7.43", what are the just the half shaft lengths for the 410/413 ?
I do have the Samurai length, but I need someone to confirm the 413/410 length.
413 vs Samurai Half Shaft Lengths
- Rabid Rhino
