Window winded....how the #>¥! do you get 'em off!
Pishadeperro
Post by Pishadeperro » Mon Aug 14, 2017 8:09 pm
Finally found a couple of tin doors but need to weld the inevitable rust at the bottoms and paint them...so need to stop the, down but can't get the window winders off, tried to feel for a clip but to no avail and because I can't see the problem I have no idea what I'm up against..can anyone help?
Re: Window winded....how the #>¥! do you get 'em off!
Post by Darrell » Mon Aug 14, 2017 8:37 pm
Post by donkeychomp » Mon Aug 14, 2017 9:11 pm
Yep, fold the plastic outer cover inside out and you can see the pin. If you lose it you can cut down a rivet and use that.
Pishadeperro
Post by Pishadeperro » Mon Aug 14, 2017 9:18 pm
Is'nt the outer sheath too stiff for that?
Post by Darrell » Mon Aug 14, 2017 11:31 pm
You could ask this chap to help, he's great with Suzuki interiors!
https://youtu.be/VJYZfdC4RQ8
Pishadeperro
Post by Pishadeperro » Tue Aug 15, 2017 7:10 am
Darrell wrote:You could ask this chap to help, he's great with Suzuki interiors!
Please don't tempt me.....I'll need a bigger hammer!
juncopartner
Post by juncopartner » Tue Aug 15, 2017 10:18 am
I used to press down on the plastic cover with a flat bladed screwdriver, knock the pin partly through with a pin pinch. the pin punch then holds the plastic cover back, you then press down on the opposite side with the screwdriver and tap the pin the rest of the way out,
Post by donkeychomp » Tue Aug 15, 2017 9:03 pm
My doors are apart at the mo. Use a little flat head screwdriver and prise it back, it's pliant enough.
Pishadeperro
Post by Pishadeperro » Fri Aug 18, 2017 9:03 am
Yup...got it...it's easy when you know how, but now I've taken the door panel off I can see that some of the window mechanism is missing...so along with the fact that the doors need welding work and more window bits I'm going to bin the idea off having them repaired and stick with my canvas doors until i can find a better or a least complete pair of tin doors
Post by ScottieJ » Fri Aug 18, 2017 9:06 am
How bad are your doors? I have a few sets and would poss P/X a set of yours aren't too bad.
