Facet fuel pump
Gardiner
Facet fuel pump
Post by Gardiner » Sun Aug 20, 2017 6:37 pm
Ok so some thoughts please, So im planning on getting a fuel cell in back and would like to put a facet fuel pump on her with the SU, what about the return as the manual pump has a return how will this work with electric pump ??
Re: Facet fuel pump
Post by ScottieJ » Sun Aug 20, 2017 7:47 pm
You don't need a return with an electric pump.
Personally I'd just keep the mechanical pump, there's no need to run an electric pump unless you have an engine that was originally spi so it doesn't have a mechanical fuel pump.
Mechanical pumps are more reliable and not noisy.
Gardiner
Re: Facet fuel pump
Post by Gardiner » Sun Aug 20, 2017 8:15 pm
Thanks for that I will do that then I have now a couple of options there are some tidy alloy fuel tanks the only thing which might cause me is the return as it will be a bit higher on the other tank hopefully the return will suffice
Re: Facet fuel pump
Post by ScottieJ » Sun Aug 20, 2017 9:06 pm
Will be fine, I've ran a few tanks in the back, some of which had returns that are quite high up.
Gardiner
Re: Facet fuel pump
Post by Gardiner » Tue Aug 22, 2017 9:08 pm
Great stuff
