Don't let the pics fool you.....it's a mess! So lets start with a good ol' tear down
![Shocked :shock:](./images/smilies/icon_eek.gif)
I wasn't impressed when I had a proper look.
This should be an instant MOT fail
![:S :S](./images/smilies/Confused.gif)
Nice Illegal chassis mod for a power steering conversion, this involves cutting the Vin number off the chassis and welding it back on as a 'plate' something VOSA and the DVLA would not be happy with.......let alone the chassis notch
![Mad :x](./images/smilies/icon_mad.gif)
This is why you should not do box section body lifts
So the 'new' gearbox mount/crossmember has bent and well round holes would be nice
Fuel and brake lines just zip tied together and not properly attached to the chassis.....also should have failed MOTs
And well then there's the welding Oh and the winch tray that was attached with 1 10mm grade 8.8bolt and Just the two braces sticking out of the side of the tray so maybe 3-4" of weld, I'm quite impressed it's still attached to be honest.
So after seeing all this it's just not worth the time it would take to save this chassis.
We are going to use the body on another chassis and this one will take one final journey to the only place it's good for.......the scrap yard.
