hey guy
i have a Suzuki samurai 1992
for the last 4 weeks i have been plagued with this fault. this is what happens:
driving along till you apply the indicator car will cut out
the indicator relay buzzes till the ignition is turned off and the ignition lights are on but very dim almost like it isn't getting full power
turn ignition off and back on again dash lights are normal and car will start
it also does the same fault when placed in to reverse
the weird bit is it will ONLY DO THIS AT RANDOM TIMES , its not constant , you can go days without seeing this fault then its back again and it will do it everytime for a while
really need help with this one guys so any help is appreciated
many thanks
luke (roadrunner)
a real mystery
a real mystery
- car meet.jpg (115.38 KiB) Viewed 3398 times
Re: a real mystery
I would say a short somewhere, maybe on the fuse board
