How to fit hard top
Girvy
How to fit hard top
Post by Girvy » Tue Jul 29, 2008 9:58 pm
Hi Folks,
Im a brand new SJ owner.... a total novice in every sence. The vehicle I bought has a soft top fitted, was supplied with a hard to in several pieces, A glass section, a plastic section x2 window sections and a rear door feame and window section with a pole thinggy attached. There are some things that look like kinda runners or fixers. Does any one have any drawings of how this is ment to fit or no any one in the glasgow area who wont cost an arm and leg that will be able to assist fitting this hard top....
Thanks guys :oops:
Zukipilot
Re: How to fit hard top
Post by Zukipilot » Tue Jul 29, 2008 10:28 pm
First, welcome to the club.
To start, depending on what type of hardtop you have, the rear glass section will either fit onto the rear door or the hardtop itself. The two side windows fit to the top of the roof section, and the glass bit you mention should fit over the front of the cab with the addition of a few pieces of rubber that you shold have had supplied with the hard top.
If you can post some pics of the hardtop, I will be able to give you more detailed instructions on how to fit it to the SJ. There are so many different types of hardtop, each with thier own methods of fitting them (although they are all pretty similar).
Different types are:
  • * One piece with rear door glass fitted to top
    * One piece with rear door glass fitted to rear door
    * Two piece - solid rear section with rear door glass fitted to top
    * Two piece - solid rear section with rear door glass fitted to rear door
    * Two piece - multi piece with rear door glass fitted to rear door
    * Two piece - multi piece with rear door glass fitted to rear door and glass cabin section
These are all made by multiple manufacturers who use different methods to fix them to the vehicle
Girvy
Post by Girvy » Wed Jul 30, 2008 9:03 pm
Hi M8,
Im having probs uploading the photo's I could give you my email addy for you to send me yours and could send you the photo that way...... not a stalker..... Honest. If not i understand and will try to get a photo with smaller file size to upload soon as I can.
Thanks for your help
Zukipilot
Post by Zukipilot » Wed Jul 30, 2008 9:43 pm
Have sent you a PM with my email address. mail the pics through to me and I will get them posted on the forum
Zukipilot
Post by Zukipilot » Thu Jul 31, 2008 6:12 pm
Here is the pic from Girvy
Zukipilot
Post by Zukipilot » Thu Jul 31, 2008 6:24 pm
Begin by bolting the sides onto the top with M6x20 bolts. Don't forget to use washers. Get a willing helper to help you lift the canopy onto the SJ. Fix it on to the back of the SJ using M6 bolts (or quick release fitting clips) depending on what fittings you have with the top.
It looks as though your rear door bolts onto the rear door of the SJ. Bolt the rear hardtop door to the rear door of the SJ with the brackets you should have with the hardtop. If it is the type that bolts onto the roof section, bolt it to the roof.
The front glass section clips onto the front of the SJ. You should have either three pieces of rubber, or a single "U" shaped piece of rubber that fits over the front and sides of the SJ. Fit this on first, and then close the clips.
Girvy
Post by Girvy » Thu Jul 31, 2008 8:33 pm
Hi ZP.
Thanks alot dude.... will gie it a blast at the weekend and ill let you know how I get on
Girvy
Post by dan_2k_uk » Thu Jul 31, 2008 8:57 pm
ZP if ur pullin that info off the top of ur head u need guiness world record for human library!
urbanzook
Post by urbanzook » Thu Jul 31, 2008 9:12 pm
dan_2k_uk wrote:ZP if ur pullin that info off the top of ur head u need guiness world record for human library!
