.? Temp gage soaring intraffic
Ewan
Post by Ewan » Fri Apr 19, 2019 6:47 pm
2003 grand vicarage, 3 door. Runs fine, but today stuck in traffic for 10 mins gauge went into the red, went back down when in clean air.
Car new to me, doesn’t appear to have used coolant etc.
Great full for any advice as this has worried me, many thanks
Re: .? Temp gage soaring intraffic
Post by ScottieJ » Fri Apr 19, 2019 6:53 pm
So as soon as you started moving and there was air flow through the rad it dropped again?
Sounds like you might need a new viscous coupling on the fan, you can test it using a rolled up bit of newspaper, when cold you should be able to stop the fan with the newspaper while the engine is running. But once up to temp it should shred the newspaper to bits as the coupling should lock up.
Ewan
Post by Ewan » Fri Apr 19, 2019 7:08 pm
Thanks il try that
