Heavy bang when braking
The Pipe Otter
Post by The Pipe Otter » Wed Nov 11, 2009 8:57 pm
Hi all, my 96 Sammy has developed a heavy bang at the back end when I brake both foward and backward, I cannot see any thing loose no broken bushes or springs, the brakes work fine, the bang is so hard its like you have hit some thing. could it be the diff any help would be helpful cos I am running out of ideas, under progressive braking it dosnt happen
carnut
Re: Heavy bang when braking
Post by carnut » Thu Nov 12, 2009 12:09 am
hi fellow,, if i were you, i would whip the rear drums off and check the shoes. but the load bang sounds like a broken spring leaf or bush. if you hold the prop, can you push the axle/diff casing up and down??.
andy
