oil leak
Posted: Mon May 11, 2020 8:10 am
hi everybody i have a problem i was a mechanic years ago i have an oik leak looks like the rear crankshaft seal and lately it has started leaking from what looks like the front crankshaft seal so i checked the rocker cover breather and it was blochen with grey gunge its definately not the head gasket its only because i do short runs it seems better since i cleaned the breather i havent taken the rocker cover off when the engine running the breather on top of the rocker cover is clear any ideas is this a problem with samurais /the breather pipe from the rocker cover goes to the air filter with a t piece but the one from the t piece has been blocked off and the inlet on the manifold blocked off i dont think this is the problem as i have had the anus for 4 years and it was ok then mybe the breather was the problem the engine oil hasnt been changrd fot about 4 years but has not don hardly 200 miles in the last 4 years could it be the thin oil finding the leaks thankyou toy in cyprus
