Sq416 front diff oil leak
Wwmsg00
Post by Wwmsg00 » Thu Jun 18, 2020 6:36 pm
Hi all, I have a 2002 1.6 grand vitara, sq416. I have an oil leak in the front diff, its coming from where the offside driveshafts enters the diff. There appears to be quite a lot of play on the shaft. Apparently there is a technical bulletin TS 06 05227 which shows fitting a support, drive shaft and seal to overcome this problem. Part numbers are 27619-65D00 and 09283-35008. The bulletin does not list my sq416. Can anybody shed some light on this please. If anyone from suzuki technical is reading this I would love to be able to speak with you.
Many thanks, mike
