Bit late to the Vitara club
Just purchased a 58 Vitara
Went to change the disc's and pada today, but both bolts have snapped in the caliper hanger/carrier
Am struggling to find a replacement part of even the oem number for it
Any help would be appreciated
Thanks
Bill
Can't find item part number, Vitara caliper carrier
Re: Can't find item part number, Vitara caliper carrier
I've used the partsouq.com site to enquire about parts from a Suzuki dealer here in New Zealand and the numbers matched their database.
There's many Vitaras under the European section so you'll need to select the right one but a couple of models I looked at showed the bolts as item 16, part number 0911712012 on the diagram - for example. It's a 12mm thread, 35mm long and probably the 1.25mm thread pitch. Any fastener supplier should be able to supply these in a suitable strength.
