SJ410 Front Brake Caliper HELP!
Hooded
Post by Hooded » Thu Mar 11, 2021 3:57 pm
Hi,
Changing my old heavily rusted front calipers, for new ones. Came across a Jimny caliper (Part Number - 55100-81A10) that looked very similar to my SJ410 caliper (Part Number - 55100-80010). Would this be compatible?
Both the brake disc thickness (10mm) and Piston Diameter (51mm) are the same on both calipers.
Any help or suggestions would be greatly appreciated.
I have attached some images below:
https://imgur.com/a/LLDFTta
Re: SJ410 Front Brake Caliper HELP!
Post by ScottieJ » Thu Mar 11, 2021 9:33 pm
Yes, Jimny calipers fit Japanese built Sjs that had aisin calipers.
Hooded
Post by Hooded » Fri Mar 12, 2021 7:00 pm
Thanks for the reply, I have ordered some now. Will the original mounting bolt be long enough or will I need to use a Jimny bolt? The only reason I say this is because the caliper mounting bush looks thicker than my old SJ caliper?
I've attached a image of what I mean below.
https://imgur.com/sjVKBnq
Kind Regards
Post by ScottieJ » Fri Mar 12, 2021 9:20 pm
Oh actually now you mention it the slider might be a bit longer so you might need longer bolts, I seem to remember running into this when using jimny slider pins on sj calipers, i think.....it was a while back :lol:
