Engine won't fire up
Posted: Mon Mar 15, 2021 1:10 pm
by RichyP
After months of short runs and having old fuel in the car for so long a engine management light came on. I dropped the oil, drained fuel and coolant then put all new filters oil and fuel back in as it needed a service anyway. Tried firing it up and no luck, cracked the injectors thinking there could be an airlock and nothing coming out of the injectors. Fuels getting to the filter so I don't think there's a problem with the pump or wouldn't have thought it would reach the filter? Timing belt fine and all other belts turning as they should so thinking its definitely fuel related maybe glow plugs? Temptation is there to use easy start but don't want to really go down that path unless I have to. Any ideas or suggestions greatly appreciated hoping its something simple I've missed.
Re: Engine won't fire up
Posted: Mon Mar 15, 2021 3:10 pm
by Larry
So it was starting ok before the service? If so, it's unlikely the glow plugs will have stopped working suddenly, unless they are disconnected?
It sounds like air lock if there's nothing at the injector.
Posted: Mon Mar 15, 2021 8:29 pm
by d_r_1989
Is this an engine that you can crack the injectors off to bleed fuel through? Normally what id do when my transit was run dry. Although my sprinter i had to keep turning over and it eventually fired.
Posted: Mon Mar 15, 2021 8:52 pm
by RichyP
Forgot to say the engine cut out on me less than a mile from home, started it up that's when the engine management light came on. Started up 1st time fine and drove back. Didn't drive it after this and got all the usual service bits but once I'd done this didn't matter how many times I'd tried cranking it no joy. I think it's an airlock but not sure where?
Posted: Mon Mar 15, 2021 8:55 pm
by RichyP
Yes you can crack the injectors off on this, when the engine wouldnt fire up after a few attempts thought doing this would solve it but no joy. Only other thing I can think of is that there's a blockage from the outlet of the filter to the fuel rails feeding the injectors maybe?
Posted: Mon Mar 15, 2021 10:55 pm
by d_r_1989
Is it a filter insert in a housing or a stand alone filter? I remember an issue like this years ago, the plastic filter housing had a hairline crack and wouldnt start after filter change, constantly sucking air up
Posted: Mon Mar 15, 2021 11:05 pm
by d_r_1989
Posted: Tue Mar 16, 2021 10:24 am
by maxaret
Do you have a hand priming bulb or pump Richy ?I am not 'au fait' with this particular engine.
On my older diesels I used to switch ign 'on' and then used the hand primer to get fuel through the system.
On a later car without a hand primer I once used a cheapish pattern fuel filter and ended up with starting problems,I then fitted a really good quality filter and all was ok - that problem had definitely been caused by air ingress through the filter connection seals.
If all else fails - might be worth checking if the fuel shut off solenoid is working ok and does not have a loose/damaged wire etc.
Posted: Tue Mar 16, 2021 10:26 am
by maxaret
Also are you getting any fault codes ??
Posted: Tue Mar 16, 2021 7:26 pm
by RichyP
Hi maxaret currently on a block of shifts but will investigate the fuel solenoid on my next day off hadn't thought of that one 👍 it's a pump on my model engine. Haven't had chance to get a fault reader on it yet but could borrow one from someone I know might shed some light on the problem
