Temp gauge not working after clutch replacement
Kevinf
Post by Kevinf » Sat Jun 08, 2024 10:25 pm
Just replaced the clutch in daughters 2003 1.3 jimny, it got recovered back home courtesy of RAC
On first drive out engine warning light came and won’t reset even after disconnecting battery also noted temperature gauge now doesn’t work checked plug at sender and reconnected several time
Also idle speed now lower than normal, doesn’t cut out and otherwise drives normal
I can only assume these issues are all related, does anybody have any idea where I can get any wiring diagrams etc so I can check power supply and earth to the temp sender I have already checked what I assumed was the earth but found an high restance and the voltages too low to make sense.????
Thanks in advance Kevin
