http://cgi.ebay.co.uk/SUZUKI-SJ-REAR-WH ... _984wt_939
take a look at that.
i want to get 2 new rear wheel bearings but i dont really want to get them from parasource as im not keen on the company but i cant find these double seal bearings anywhere else.
has anyone used these?
parasource rear wheel bearings double seal?
Re: parasource rear wheel bearings double seal?
if you take the number off the bearing,, then contact a bearing supplier, they can then match up the bearing for you.. i used to use avon seals nr weston-super-mare. plus loads cheaper!!
andy
andy
What a load of crap! all the rear wheel bearings i have ever bought are fully sealed! you still need the inner seal! just get a bearing kit from you're local motor factors! the only reason the inner seal will fail anyway is because the bearing has failed. in a bearing kit you get a new inner seal.
thanks alot for the heads up! thats the last time i even look at anything associated with parasource!
how much should i be looking to pay for a pair of real wheel bearings? mine are shot!
I got mine from this place. They seemed ok. About £32 each, and im pretty sure that came with the oil seal. But as was said before it would still be cheaper from a proper bearing supplier.
http://www.japanese4x4spares.co.uk/index.html
