rubbish lights
jutwit
rubbish lights
Post by jutwit » Tue Jan 12, 2010 5:57 pm
hi guys, my head lights are rubbish, just yellow and not very bright compared to newer cars, would putting brighter bulbs in do the job or will i have to replace the whole units? is it only golf lights that fit in or any other ones fit?
Re: rubbish lights
Post by Tramp » Tue Jan 12, 2010 7:31 pm
look there are a few options to you, I ran upgraded bulbs for around a year, and then i got a bad connection on my fuse box and they stopped working, so i went back to the originals. I suggest that instead of doing anything with the originals fit some good spot lights that way when you put your full beam on you should be able to see everything!
If you change the light units to other your still tied to the original wattage because of the wiring. But...... if you upgrade your wiring you could upgrade your bulbs
carnut
Re: rubbish lights
Post by carnut » Wed Jan 13, 2010 4:10 pm
or,, fit relays, then you can use brighter bulbs.. it could just be, the refelecter on your lamps have tarnished, i use golf lamps, plus they have built in sidelights, and there prity good.
andy
