Wiring diagrams
Wiring diagrams
Post by ScottieJ » Thu Feb 25, 2010 12:21 pm
Save these to your computer and view to zoom in enough to read them
European wiring diagram PDF
Or Jpeg version: Covers Japanese SJ410s
jap sj/sammy wiring diagram, drawn up by Corey "dice" Daniel's off zuwharrie.
90-92 (TBI) US wiring diagram
90-92 canadian Samurai diagram
Spanish Santana sj410 wiring diagram: please note Darrell and I have put a lot of time into this to tidy it up from the original copy we got hold of that was almost incomprehensible, Hopefully there aren't any errors :thumbup:
Spanish Santana Samurai wiring diagram (when I get a chance i'll do a proper scan and tidy this up)
Both of the Spanish diagrams aren't great and it's hard to tell what the colours actually are, hopefully this will help in some cases, this is or the early spanish SJs with the PCB style fuseboard. Its the colours that leave each fuse, not the feed colours. Also in brackets at the end are possible alternative colours, I have a random spanish dash loom with those colours.
Fuse 1 Red. high beam
Fuse 2 Red-white. dip beam
Fuse 3 White. permanent live, horn, clock and interior light
Fuse 4 Green-silver. brake lights
Fuse 5 White-green. hazzards
Fuse 6 White-black aux
Fuse 7 Black-white. ignition live
Fuse 8 Brown-green Heater blower (Yellow-green)
Fuse 9 Yellow-green. Demister
Fuse 10 Brown-black Wipers (Yellow-green)
Fuse 11 Yellow. Reverse light
Fuse 12 Red-yellow, dash lights, number plate lights.(Red-green)
Fuse 13 Red-green, Right side and tail lights (Red-yellow)
Fuse 14 Brown-yellow, Left side and tail lights (Red-black)
Rjmaas512
Re: Jap SJ/Sammy wiring diagram
Post by Rjmaas512 » Sun Apr 17, 2011 8:42 pm
Useful wiring diagram. Do you have one with the rear wiper motor and switch as the one I have found in my electronic haynes manual is not the best resolution scan, meaning that I can't see what colour wire goes where.
Don't mind if it is a black and white copy as long as i can see what the colours are.
Cheers,
Rob
Post by ScottieJ » Mon Apr 18, 2011 1:15 pm
I'm not sure if i do, just had a look through the other wiring diagram I have saved on my pc and i cant see a circuit for the rear wiper?
I'll see if i can find you one though :thumbup:
Post by Darrell » Mon Apr 18, 2011 8:14 pm
I've also looked though my diagrams and can't find any rear wiper drawings for a SJ/sammy only the vitara. Sorry :er:
Rjmaas512
Post by Rjmaas512 » Mon Apr 18, 2011 11:38 pm
Dam thats a pain thanks for looking though, I will try and work it out with a meter and see what I can get working.
Post by ScottieJ » Mon Apr 18, 2011 11:49 pm
What colour wires do you have there? There is a chance they used the same colours on The vitara. Some of suzukis wire colours are standardised, others are a mystery :lol:
Post by Darrell » Tue Apr 19, 2011 9:26 pm
I found this for the vitara. Wouldn't expect the sj to be much different. Hope it's some help.
Rjmaas512
Post by Rjmaas512 » Tue Apr 19, 2011 11:08 pm
ScottieJ wrote:What colour wires do you have there? There is a chance they used the same colours on The vitara. Some of suzukis wire colours are standardised, others are a mystery :lol:
I have at the switch, blue/back, blue, pink and white. Have worked out that the pink wire is the washer motor, so thats not a problem.
I think the white wire is the trigger for the wiper and one of the other two wires is the permanent power to the motor.
When i put a meter on the wires to try and work out which one is live with ignition on, i get a connection between both the positive and negative of the battery for the (i think blue and black wire).
I basically need to work out whats what and plug it into the switch somehow...
If someone has a rear wiper switch on their SJ a picture of the wires connected to the switch would probably sort the problem out.
Hope thats useful Scottie
Darrell wrote:I found this for the vitara. Wouldn't expect the sj to be much different. Hope it's some help.
Thanks Darrell for the diagram. It allows me to see what goes where, so hopefully with a meter and some working out whats what I can connect my switch up properly. Will let you know how I get on.
Re: Wiring diagrams
Post by Darrell » Sun Jun 10, 2012 9:26 pm
Your spanish wiring diagram is the only one I've seen and I only just spotted it :oops:
So I though it could do with a tidy up :D
Took me blooming ages :S
If you see any cockup's let me know ;)
After
After
Before
Before
Re: Wiring diagrams
Post by ScottieJ » Sun Jun 10, 2012 9:42 pm
Awesome, cheers Darrell, one of our members from Spain found it for me. I spent a good few hours cleaning up all the linework myself so I dread to think how many hours in total its had spent on it now. There is one fuse that was on the crease between the 2pages that I just need to work out where the wire goes and I think its finished!
Oh and what program do you always use to add the txt?
