3" body lift
Posted: Tue Sep 23, 2008 9:28 pm
by urbanzook
phase 2 3" body lift.
dun the lift sat after it arrived fri.
tested it sunday check my you tube for the vid
http://www.youtube.com/watch?v=6ioP3j8bWA8
Re: 3" body lift
Posted: Wed Sep 24, 2008 9:05 am
by zook123
i see you also bought yourself a pressure washer
Re: 3" body lift
Posted: Wed Sep 24, 2008 1:41 pm
by bourneyo
looking sexy!
as does the pink mobile
Dan
Re: 3" body lift
Posted: Wed Sep 24, 2008 5:13 pm
by urbanzook
the last pic is when i sprayed it befor the lift. to show the dif.
iv never washed it sins i sprayed it. i do have a pressure washer but i wont use it as i fear the body will fall a part.
i sweep it when is dry. then sweep the floor. rather than get wet sticky mud every where all ova the road fence other cars is bad enough when it falls off.
the phone is my missis.
Re: 3" body lift
Posted: Wed Sep 24, 2008 6:16 pm
by trotter
where did you get it from? (the lift kit that is not the pink phone or pressure washer)
Re: 3" body lift
Posted: Thu Sep 25, 2008 12:05 pm
Lookiing pretty good there matety! time to squeeze some bigger rubber on eh!
It looks like a LAsupertrux body lift kit!
Re: 3" body lift
Posted: Thu Sep 25, 2008 8:20 pm
by urbanzook
scottie is right is LAsupertrux body lift kit.
my rubber is big enough
Re: 3" body lift
Posted: Fri Sep 26, 2008 12:08 pm
What size are they? 31x10.50r15? it is probably the best size to run to avoid lots of transmission problems
I would also see if you can get away with putting standard shackles back on now that you've got the body lift! it will improve your approach angle and make your springs last longer.
Scottie J
Re: 3" body lift
Posted: Fri Sep 26, 2008 5:16 pm
by urbanzook
yer 31 10.50 15 tell my mate that he wants 36".
ill keep the shackles on as my approach angle is the same as a standard anus.
im also planing to do s,o,a witch will increase approach angle above standard.
my springs will last as long as thay will wot ever i do, iv accepted is a money pit!
an hay when they do go it will be time for coils. :o)
