wet feet
Posted: Mon Apr 05, 2010 11:01 am
by ROBBIE
had this prob for ages, when it rains water drips onto me feet :cry: its not coming in under the screen (its a sammy soft top) or the heater vent, its taped over. any ideas?
Re: wet feet
Posted: Mon Apr 05, 2010 11:06 am
by Edweird
Is it constant when it's raining, or is it only when you press a specific pedal whilst it's raining?
Random anecdote; My mum's Range Rover Classic used to drip water onto people's feet when it was raining, but only when you pressed the clutch pedal.........
Re: wet feet
Posted: Mon Apr 05, 2010 11:19 am
by ROBBIE
constant and on both driver and pasenger
Re: wet feet
Posted: Mon Apr 05, 2010 8:21 pm
by Edweird
:!: Air vents? :!: Could water be coming down through the foot air vents? :shock:
Re: wet feet
Posted: Tue Apr 06, 2010 1:32 am
by Tramp
i get a leak when its raining, I heard that on the soft top sjs there is a seal that runs between the windscreen and the bulkhead, this can perish and leave you with wet feet, to get at it you have to fold the windscreen down I never got around to doing mine, its only a slight drip anyway.
Luke
Re: wet feet
Posted: Tue Apr 06, 2010 9:22 am
as luke says! :mrgreen:
Re: wet feet
Posted: Tue Apr 06, 2010 12:22 pm
by ROBBIE
cheers guys but its not the seal sorted that out when i put it back after it fell over last year :lol:
Re: wet feet
Posted: Tue Apr 06, 2010 8:18 pm
by Pugsley
Check the two rubber water drainage thingy's which you can see mounted on the bulkhead (at the rear of the engine) - mine leaked so I removed them and refitted with gasket compound to provide a water tight seal.
Re: wet feet
Posted: Sat Apr 24, 2010 9:54 am
by albertross74
I used to get wet feet in my hardtop, seemed as if it was coming from underneath the glovebox/ speedos.
Dad suggested taking off the wipers and rubbing grease around the seals where the wiper mounts go into the car. Seems to have worked a treat.
Re: wet feet
Posted: Sat Apr 24, 2010 8:30 pm
by 4eye
have you tried to locate the leak via hose pipe....ie...jet a spot for a few mins then check the footwells....then move to another...work from the bottom up and you should find the bugger! (hopefully :P :lol: )
