Screeching Noise
Posted: Thu Apr 08, 2010 7:18 am
HI there guys - another query from Poland
Had that problem with the starter before but now working fine - but after I got it reinstalled and starting again properly we have another problem.
You know that horrible SCREECHING noise you sometimes hear on other cars and always say 'thank GOD that's not mine' - well now it is MINE
. Always thought on other cars it sounded like a massive brake problem - but for sure engine related as only occurs when not braking.
Funnily it only SCREAMS for about 10 seconds when I start her up and then doesn't reoccur during normal driving. And also seems to be not so bad now it's getting warmer ! ! !
Also seems she is a little down on power - but to be honest we only ever got up to 100km going downhill anyway. But just does not seem to want to rev above 4000rpm in 4th or 5th.
Noticed when I reinstalled the starter that the oil was a bit low, so keeping a close check on that now but now apparent heavy oil usage or leaks - I assumed as it's somewhere inside that there may be a lubrication problem.
Any bright ideas or anyone had similar experience and knows what it is and what's the cure
Cheers again as always
