what do you reakon
Posted: Sun Jun 27, 2010 3:24 pm
by the fool
hi all
i have a 15 td corsa engine in my sj whats the benefit from putting a 17 td in there
as i have one lying around is it just making work?
Re: what do you reakon
Posted: Sun Jun 27, 2010 9:46 pm
well you get more power so why not
Posted: Mon Jun 28, 2010 11:29 am
by hucky
im guessing the 1.5 and 1.7 would be a stright swap with no messing about.
service the engine while its off, change everything that could go wrong and pop it in
Posted: Mon Jun 28, 2010 11:31 am
by Edweird
I'm pretty certain the engines are identical to look at. They put both in the MK3 Cavalier (and Fronteras too if memory serves), so I think the mounts are the same. Just change the ECU as well, as the wiring should be virtually identical too.
Posted: Mon Jun 28, 2010 7:54 pm
by the fool
well all i have just got a new job which is good (was getting bored ) the trouble is that i have to work away pretty much all the time plus weekends so am going to leave the 1.5 in there
intil i get time to do swap or blow it up you all know which will happen first
Posted: Tue Jun 29, 2010 12:39 pm
