Rear Wheel Bearings
Stats696
Rear Wheel Bearings
Post by Stats696 » Wed Jul 28, 2010 10:34 pm
I am in need of a new rear wheel bearing for my SJ413, is there a part supplier anyone recommends?
Is this a job where it will be best to change both rear bearings while your at it?
Many thanks
Henry
Re: Rear Wheel Bearings
Post by Henry » Thu Jul 29, 2010 9:04 am
Hi
I got my bearings from a suzuki main stealer.
Honestly if your going to the trouble of doing one, do the otherside too.
A fairly simple job once you have got the shafts out, and if you have a bearing press.
Post by ScottieJ » Thu Jul 29, 2010 12:50 pm
Yeah i'd say it's best to do both at the same time, if you dont it's pretty much certain the other side will fail shortly afterwards.
Just go to a motor factors and they should be able to do a kit for about £40 with a new bearing, spacer,oil seal and locking collar
here's a 'how to' guide if you haven't got a press :mrgreen:
http://forum.difflock.com/viewtopic.php ... el+bearing
