fixed to broke in 3 miles
Posted: Mon Sep 20, 2010 6:59 pm
by 4eye
Re: fixed to broke in 3 miles
Posted: Mon Sep 20, 2010 9:16 pm
by Tramp
most people mange to break their sj's ragging them off road! did you manage to hole a brake seal?
don't all sj's leak from the front cv housing? your is just a little wetter than most!
Posted: Mon Sep 20, 2010 10:35 pm
by 4eye
cv housing never used to leak and i haven't looked in the drum yet as I'm a tad busy with decorating/gutting my house...hope to take a gander this sunday...need to fix it before the cold weather sets in.....just cash is tighter than a nuns at the mo.....
how's thing anywho.....all good i hope
Posted: Tue Sep 21, 2010 12:21 pm
the front is just the inner oil seal, easy to fix and nice and cheap
is it oil or brake fluid on the rear??? if it's oil its most likely the bearing has failed causing the oil seal to fail, new bearing kit time me thinks
you should be able to fix it all for under £50
Posted: Sun Sep 26, 2010 2:53 pm
by 4eye
after more than a few whacks with the old hard rubber mallet the drum casing finally loosened.....
Posted: Thu Oct 07, 2010 10:50 pm
by 4eye
[quote="scottiej410"]the front is just the inner oil seal, easy to fix and nice and cheap
[/quote
the wife phoned the dude for my parts i need (as she has time to spare
) asked for the seal on the front but he knew not of wat she were on about.?? just to be clear it is called.... inner oil seal.
