vitara 8v engine into my sj
lightning
Post by lightning » Tue Nov 23, 2010 12:03 pm
Hi,
I have been planning to put a vitara 8v engine into my sj
Do i use the vitara gear box ?or the sj gear box with a conviersion plate?
Mark
Re: vitara 8v engine into my sj
Post by twiss » Tue Nov 23, 2010 12:15 pm
Is it an SJ413/Samurai, or an SJ410?
lightning
Post by lightning » Tue Nov 23, 2010 1:55 pm
sj410
I know that the 410 gear box will not fit and i will have to get a 413 gear box and fiy wheel and clutch pos a prop shaft
Post by twiss » Tue Nov 23, 2010 2:20 pm
Well with a 410, you will have to swap the gearbox anyway, so you could go either way really
413 gearbox, clutch, prop, etc...
or
vitara gearbox, clutch... I think the vitara method would probably be more work... but better
only thing is though I think they are reasonably different in ratio.
Scott, isn't that the setup you have? Vit engine+gearbox and a SJ t-case?
Post by ScottieJ » Tue Nov 23, 2010 4:35 pm
Close! I have a vit gearbox, modified vit tbox and Sj tbox :mrgreen: the easiest option is deffo a 413 gearbox but.......
Someone else asked exactly the same question on Monday have a look here to save me typing it all up again! :lol:
http://www.suzukiclubuk.co.uk/phpBB3/ph ... =13&t=2606
oh and you only need a prop if you have skinny props on your 410. From around 84ish onwards all 410s have the larger props.
lightning
Post by lightning » Tue Nov 23, 2010 6:59 pm
Thanks boys for the help
I am going down the 413 set up gearbox, clutch, prop, etc...
Do you have to use the conviersion plate? i heard it makes the clutch judder :?: :?:
I can get a new clutch from my brother he owns a clutch place :lol: :lol:
Right anyone got gearbox,flywheel, prop,for sell??PLEASE
dunk
Recommended Trader
Recommended Trader
Post by dunk » Tue Nov 23, 2010 7:10 pm
Post by ScottieJ » Tue Nov 23, 2010 7:24 pm
Nowt wrong with that dunk :lol: :lol: I would've done the same :mrgreen:
