4x4 newb
maisey
4x4 newb
Post by maisey » Fri Jan 07, 2011 2:51 pm
been a member since christmas and owned my little zooki for about three weeks. coverd just under four hundred miles in it and can say they have been the most entertaining with avoiding the dual carriageways as much as possible as they are boring as it is when your doing 70mph ;) so fifthty takes the biscuit. Lovely car juat to take a moment and smell the roses, but in my case sometimes theres a burning plastic smell have put this down to a crank shaft oil seal. Like peeps advice on some slight mods for her would like to keep as much of it looking as standard. To my surprise or as far as the eye can tell there is no rot no any of the arches. Was a bit concered about the throttle pedal that was hanging on by a thread, the original metal around the stud had rotted away so quick repair for now with reapir washes m10 and nut.
03jamtur
Re: 4x4 newb
Post by 03jamtur » Fri Jan 07, 2011 3:01 pm
nice if i got a small zook this is what mine would look like smart mines lwb very nice thow dose it run well ??
maisey
Re: 4x4 newb
Post by maisey » Fri Jan 07, 2011 3:12 pm
03jamtur wrote:nice if i got a small zook this is what mine would look like smart mines lwb very nice thow dose it run well ??
had the choice between swb or lwb would have to be lwb, although with one seat removed in the rear got enough room for tool box. On start up it idles quite high, mean high like 2 thou with bit of smoke but been told at college this is normall for the weather. mpg is quite poor full tank gets me like hundred and forty miles :argh: but got to replace the original fuel filter :roll: so that might help. was looking at vitara conversion.
Re: 4x4 newb
Post by twiss » Fri Jan 07, 2011 3:14 pm
:welcome:
Nice tidy zook you've got there... Should be OK off road with those A/Ts on it...
Although, First mods I would consider it a set of mud terrain tyres....
I would recommend either the Insa Turbo Saharas (my old tyres)
or Kumho KL-71s (currently tyres)
both are well behaved on and off road...
After that I would maybe look at 2" lift and some wheel spacers... I find that to be a perfect initial setup...
will give decent amount of ground clearance, and increased stability
Avoid extended shackles like the plague. The best value way to lift 2" is add-a-leaf...
Should cost roughly £100 to lift
Wheel spacers tend to go on ebay for around £50
Sets of tyres vary on type and condition
I got my current set of 5 for £170
I got the last set of 4 for £90!!!
Re: 4x4 newb
Post by twiss » Fri Jan 07, 2011 3:16 pm
Also, I would initially put the high idle speed on start down to the carburettor...
The auto choke mechanisms tend to jam or stop working properly
I fitted an SU carb and modded inlet manifold on mine, best engine mod I've done...
I'd say get an SU, then get a 1.6 engine, not the other way around
Re: 4x4 newb
Post by ScottieJ » Fri Jan 07, 2011 3:21 pm
:welcome: to scuk
Nice and tidy Sammy you got there! the auto chokes on those carbs do play up a bit but you should be able to drop the choke idle speed down, I cant remember what screw it is on the carb though.
Scott
maisey
Re: 4x4 newb
Post by maisey » Fri Jan 07, 2011 3:24 pm
its spi not carb, there is a idle sensor on the side with some 8mm bolts holding it on, with these lose there is movement for the sensor guess its a case of trail and error without a gas analyser.
Re: 4x4 newb
Post by ScottieJ » Fri Jan 07, 2011 4:03 pm
Oh yer my bad didn't realize it was a late model Sammy. :lol: not sure if the spi ones had it but on the carbed models there is an idle up to compensate for extra power drain when you turn on the lights and heaters etc. These sometimes play up so that could be part of your problem? If it has one of course? If so just dissconnect it as its not really needed.
Henry
Re: 4x4 newb
Post by Henry » Fri Jan 07, 2011 4:18 pm
Hello and welcome. nice looking zook :smokin:
You seem to be after the look that i went for.... Subtle mods, some oversized tires ect :)
If you just wanted tires, splash out on some decent tread ones, you can have the best tricked up truck in the world but the tires always make it.
My choice was a mt that went well on road :twisted:
Russ24
Re: 4x4 newb
Post by Russ24 » Fri Jan 07, 2011 4:25 pm
hello and welcome to scuk
whats this about yours doing 70mph? i wish mine did.
get some decent rubber on it then worry about other stuff.
:russ:
