Can any one tell me if Ford Sierra rear brake calipers will clear 15x10 modulars on SJ brake disc?.
I am currently using Rover 45ZS calipers but they are a bit weedy. I know Rover 800 rear calipers fit, sierra (cosworth/1.8/1.6 use similar calipers with 43mm pistons 10mm discs) are a bit more common and bigger piston/better brake?.
Cheers, Will.
Rear brake calipers with park brake
'If at first you get stuck, try harder!'
