Help! I cant get it in!
timmo
Post by timmo » Thu Mar 31, 2011 6:27 pm
Hello all,
I have a problem. Taken out the 970 lump and am putting in 413 unit with 5 speed box but it wont fit! I have 413 engine mounts but the left mount will not line up by about 3 inches and both mounts just seem too short. also the gearbox mount is different and will not fit either :argh:
Re: Help! I cant get it in!
Post by twiss » Thu Mar 31, 2011 7:43 pm
Hi yeah you will need to make and weld different engine mounts for 413 engine...
timmo
Post by timmo » Thu Mar 31, 2011 8:03 pm
Sh##t didnt need that! Anyone want a 413 engine with weber carb paddle clutch and all anciliaries? especially if you have good970 in return?
Post by ScottieJ » Thu Mar 31, 2011 8:32 pm
Hey timmo where in the country are you, there might be someone nearby that can help, its pretty darn easy to modify the engine mount on the chassis.
Henry
Post by Henry » Thu Mar 31, 2011 8:35 pm
Its a 10 min job with the grinder and welder. Cut mount off, bolt to engine drop back on chassis rail weld up :)
Like Scot said where are you people are always willing to help on hear :)
timmo
Post by timmo » Thu Mar 31, 2011 9:39 pm
Thanks for the encouragement! I live near Bury st eds in suffolk. I'm afraid I have no welder. I assume gearbox mount needs welding too?
