Page 1 of 2
hello
Posted: Mon Nov 03, 2008 11:42 am
by mitch
hi to all, just passed my test only 18 years old so be gentle with me
own a sj413, which ive spent some time on getting it road worthy, having trouble with the dip beam, side lights come on and main beam is alright, but no dip beam
not a sparky tbh any help appreciated
thanks in advance mitch
Re: hello
Posted: Mon Nov 03, 2008 5:06 pm
by urbanzook
got any
off you anus?
post them up wanna have a
tell us a bout your mods
an this one is on me
Re: hello
Posted: Mon Nov 03, 2008 7:28 pm
by mitch
hi there have not yet figured out how 2 put pics up . do u no wot my prob is wit my anus many thanks
Re: hello
Posted: Mon Nov 03, 2008 8:32 pm
by liljitjit
Re: hello
Posted: Mon Nov 03, 2008 10:21 pm
by trotter
howdy and
as for posting pics load them from phone/camera to here
http://photobucket.com/ then all u have to do is copy and paste the [img] code to a thread on here
Re: hello
Posted: Tue Nov 04, 2008 11:49 am
by bourneyo
Hello fella, welcome to the forum!
Dan
Re: hello
Posted: Tue Nov 04, 2008 1:14 pm
by dan_2k_uk
hi i take it you have checked all the fuses.
How good are you with a multimeter and how much do you know about electrical systems. Basically i would first check for a 12v supply at the headlamp connector. If there isnt one there check there is a supply to the fuse at the fusebox under the glovebox. If you have a supply there the fault must be somewhere between the fuse and the lamp. At least that will narrow it down.
Re: hello
Posted: Wed Nov 05, 2008 7:00 pm
by Tonka
Fella got any pic on yet
have one on me
Re: hello
Posted: Wed Nov 05, 2008 8:45 pm
by Zukipilot
Check that your switches are working properly. There are two. One is the main on/off switch, and the other is the dip switch. One of these may be knackered.
Another thing to check is the wiring. Are any cables chafed or broken. Also check the fuses.
Re: hello
Posted: Thu Nov 06, 2008 10:36 am
by mitch
thanks lads for the replies, will have to get some pics soon
sorted out the problem, yes it was the switch, seems to be 2 types mine was an early spanish type that had worn
cheers mitch
