rattles in 2nd and 3rd
Re: rattles in 2nd and 3rd
Post by ScottieJ » Tue Nov 04, 2008 12:02 pm
Have you checked all the UJ's on all 3 props for play and the gearbox, engine, and Tbox mounts?
Post by dan_2k_uk » Tue Nov 04, 2008 12:35 pm
when my transfer box mounts went the selector stick vibrated alot in 1st and 2nd. I would imagine if the g-box mounts and engine mounts were worn the gear stick would vibrate.
How violent is the vibration.
trotter
Post by trotter » Tue Nov 04, 2008 4:48 pm
grab hold of the rear propshaft and try to rotate it be hand
if it moves more than bout 1/4 inch in either direction the uj's prob need replacing
if in doubt, FLAT OUT!
Post by dan_2k_uk » Tue Nov 04, 2008 6:24 pm
or the inside of the rear diff looks like mine!
Post by ScottieJ » Wed Nov 05, 2008 12:19 pm
its also better to check for play with the handbrake off and everything in Neutral I find! (Just remember to chock the wheels so that it doesn't run you over while your underneath :twisted: )
bourneyo
Post by bourneyo » Fri Nov 07, 2008 3:25 pm
in the DIY page there are two methods!
ONE
TWO
If its not your daily drive take the nackered joint off and take it to the motorfactros, there are several different types for the SJ, and motorfactors always have the wrong one listed!
best of luck!
Dan 8-)
bourneyo
ONE
TWO
best of luck!
Dan 8-)
