prop spacer what u think ???
arnie
Post by arnie » Tue May 03, 2011 8:12 pm
hi iv just had a mesure up and iv i pust the rear prop right in and measure the gap between end and diff its 60 mm so i was thinking a 50 mm spacer any theorys ???
thanks arnie
Re: prop spacer what u think ???
Post by ScottieJ » Wed May 04, 2011 1:03 am
Don't forget to factor in the fact that the prop needs to compress under articulation, might be worth flexing your sj up with the diff side of the axle at bump and then measuring it. 50mm sounds too big IMO :thumbup:
arnie
Post by arnie » Wed May 04, 2011 8:27 pm
Ok I was thinking 10 would have been enuff to go up but I'll try flex it n see :). Only trouble is that's tricky at the moment as iv got no brakes I'm
In the proses of seeing what lenth flexi brake I need lol :)
Post by twiss » Fri May 13, 2011 5:09 pm
I'd be looking at a regular 1" prop spacer...
You can get them from bits4vits
http://www.bits4vits.co.uk/store/vitara ... od_27.html" onclick="window.open(this.href);return false;
