Changed the fuel pump but theres something wrong
Smalljeep
Post by Smalljeep » Wed Jun 01, 2011 10:06 pm
i swapped round the fuel pump to cure the oil leak which i believe is actually the gasket not the pump.
But anyhow now the problem is that when the cars not got any revs on it it just cuts out, say your coasting down a hill it turns off, or if you want to go really slowly in low range it cuts out and i need it for the really slow quiet mode.
so what could it be? a fubard pump or just a turn of something at the carb, i know how to adjust the idle speed but i didnt need more revs before i changed the pump.
1991 Suzuki Samurai with 1.6 8v engine
2002 Peugeot 406 HDi 110 Executive
Henry
Re: Changed the fuel pump but theres something wrong
Post by Henry » Wed Jun 01, 2011 10:19 pm
Could be the diaphram in the pump? Id put the old one on and see if the problem is still there?
If not put a new gasket in with the old pump :smokin:
Smalljeep
Post by Smalljeep » Wed Jun 01, 2011 10:29 pm
i just used a bit of instant gasket to replace the gasket i couldnt source a proper gasket yet.
Post by ROBBIE » Thu Jun 02, 2011 10:09 am
get some gasget paper from yer local motor factor an make 1 :D
Ginger_boy
Post by Ginger_boy » Fri Jun 03, 2011 4:46 pm
ROBBIE wrote:get some gasget paper from yer local motor factor an make 1
Use cardboard from a cereal packet, with some blue hylomar as a sealant have done that in the past on my old cars and havent had a problem. Instant gasket goo can have some strange reactions with oil and petrol. ;)
Smalljeep
Post by Smalljeep » Sat Jun 04, 2011 9:48 pm
i made 2 gaskets with some gasket paper, although i havent started it up yet.
Smalljeep
Post by Smalljeep » Sat Jun 04, 2011 11:52 pm
i put the old pump back on and it still runs like sh1t.
is it petrol? i put £20 in it and its only did 23 miles of quite hard driving and idling.
what sort of electric fuel pump could i replace the mechanical one with?
Henry
Post by Henry » Sun Jun 05, 2011 4:42 pm
Low pressure 3-5 psi.
facet solid state or similar
Smalljeep
Post by Smalljeep » Sun Jun 05, 2011 5:50 pm
I dont know what pressure its putting out, how do you measure it?
i had the anus out last night going slow in low range and it was terrible it was jumpy and all wrong, it stalled and i left it in the field, went back this afternoon and it drove back to the shed ok but its still going poop, here is how its idling at the moment:
Click Here for Youtube Video
Henry
Post by Henry » Sun Jun 05, 2011 6:18 pm
It says your video is private and wont play.
